TwinTurbo.NET: Nissan 300ZX forum - If the interior lights won't go out when the doors are
compirate
on January 03, 2018 at 12:26 PM
Sure I can keep replacing the fans.
posted by FrozTTy
on January 03, 2018 at 07:22 AM
closed, then check the door switches (the ones in the door jam). Remove the switch and see if you get continuity when it's pushed in or not.
Blinking Security Light and Dome Light Operation
FrozTTy
09:15:01 01/02/18
Should add I've had issues with the cabin temp sensor
FrozTTy
13:04:43 01/02/18
Did you try a little oil?
compirate
13:50:16 01/02/18
No interior lights stay on when I close the doors (n/m)
FrozTTy
13:53:43 01/02/18
The first fan I tried cleaning, etc
FrozTTy
13:54:26 01/02/18
Maybe you can find a replacement for the motor in the fan
compirate
14:44:34 01/02/18
FrozTTy
07:22:00 01/03/18
If the interior lights won't go out when the doors are -
compirate
12:26:08 01/03/18
I said they do go out
FrozTTy
12:40:35 01/03/18
Aside from the antitheft control unit, you've got several
compirate
13:24:13 01/03/18
Wasn't there something about the 'Time Control'?
Cjw3
15:41:44 01/03/18
Time control not integrated into anti-theft
compirate
15:55:11 01/03/18
Quote: I shut the door it would dim, but stay ON.
compirate
13:25:56 01/03/18
My OP was referring to the dome light
FrozTTy
13:46:35 01/03/18
so it does go out completely on it's own?
compirate
15:03:03 01/03/18
And another repair thread goes dormant (n/m)
compirate
10:02:13 01/06/18
Well, I didn't simply try changing the bulb.
FrozTTy
07:46:29 01/08/18
Sorry, just used to these things dying off with no
compirate
09:02:29 01/08/18
